# How to inference an AI model
The Sunrise Model Service exposes an OpenAI-compatible API for every Active Model. To send an inference request you need three pieces of information: a **Base URL**, a **Model Name**, and an **API Key**.
## Make your first call
### 1. Get the Base API URL
All inference requests are sent to the Sunrise Model Service endpoint.
| Environment | Base API URL                 |
| Production  | `https://maas.ai.sunrise.ch/` |
### 2. Pick a Model Name
Choose a model from the [Active Models](../active-models.md) table. The value in the **Model Name** column is what you pass as `"model"` in your request body.
Examples:
- `inference-llama4-maverick`
- `inference-bge-m3`
### 3. Get your API Key
Your API Key authenticates every request. Pass it in the `Authorization` HTTP header:
```bash
Authorization: Bearer YOUR_API_KEY
!!!warning Keep your API Key secret
Never commit an API Key to source control or expose it in client-side code. Rotate the key immediately if you suspect it has been leaked.
### 4. Send the request
With the three pieces above you can call any of the OpenAI-compatible endpoints. The minimal chat completion call looks like this:
+++ cURL
```bash
curl --location 'https://maas.ai.sunrise.ch/v1/chat/completions' \
  --header 'Authorization: Bearer YOUR_API_KEY' \
  --header 'Content-Type: application/json' \
  --data '{
    "model": "inference-llama4-maverick",
    "messages": [{"role": "user", "content": "Hello!"}]
+++ Python
```python
from openai import OpenAI
client = OpenAI(
    base_url="https://maas.ai.sunrise.ch/v1",
    api_key="YOUR_API_KEY",
response = client.chat.completions.create(
    model="inference-llama4-maverick",
    messages=[{"role": "user", "content": "Hello!"}],
print(response.choices[0].message.content)
+++ Node.js
```javascript
import OpenAI from "openai";
const client = new OpenAI({
  baseURL: "https://maas.ai.sunrise.ch/v1",
  apiKey: "YOUR_API_KEY",
const response = await client.chat.completions.create({
  model: "inference-llama4-maverick",
  messages: [{ role: "user", content: "Hello!" }],
console.log(response.choices[0].message.content);
## See also
[!ref Sample API calls](sample-api-calls.md)
[!ref Active Models](../active-models.md)
